PeakNet and Windows XP for my old DX-120
Posted: Thu May 11, 2017 2:38 pm
by ciroscar
Hi everyone, this is my first topic here.
I'm trying to use an old Dionex DX-120 IC system on an old Windows XP PC but it doesn't work without a compatible version of PeakNet.
Someone can help me?
I have a Windows XP SP 3 and PeakNet 5.21 with a DX-LAN card 3Com EtherLink PCI TCP NIC (3C900B TCP).
Any help or ideas would be highly appreciated...
Sincerely,
Ciro
Re: PeakNet and Windows XP for my old DX-120
Posted: Fri May 12, 2017 3:16 pm
by eg@aaclab
We run that version of Peaknet on Windows 2000 with our DX-120s but have not tried XP..You might be able to run Peaknet in Compatibility mode see the link below or just search for it online.
https://technet.microsoft.com/en-us/lib ... 56991.aspx
If you describe in detail what doesn't work someone might be able to help you better...It could be the card or the driver for the card doesn't work with XP and you might have to update the driver or?
Good Luck
Posted: Fri May 12, 2017 10:56 pm
by John Guajardo
Hi Ciro,
To use your DX-120 with Windows XP, you will likely need to upgrade your software to Chromeleon 6.5 or later (e.g., Chromeleon 6.80 supports DX-120 with firmware 3.12).
Posted: Sun May 14, 2017 7:41 am
by ciroscar
Hi Ciro,
Hi John.
Which version of Chromeleon supports DX-120 with firmware 3.20?
Posted: Sun May 14, 2017 7:43 am
by ciroscar
Hi Ciro,
Hi John,
which version of Chromeleon supports DX-120 with firmware 3.20?
Posted: Mon May 15, 2017 6:45 pm
by John Guajardo
Hi Ciro, I confirmed with our firmware group that the last firmware for DX-120 was version 3.12. Not sure how you have 3.20?
Posted: Wed Feb 21, 2018 6:34 pm
by mmalmali
I have an old Dionex HPLC system, with BNC connections. Would it possible to tell me how I can get a copy of the software?
Posted: Wed Feb 21, 2018 7:25 pm
by John Guajardo
Hi
mmalmli, please contact me directly (
john.guajardo@thermofisher.com) with the serial number of your dongle, the modules in your system, and the software version you need. Please also include the details of your Windows operating system. Is this system currently connected/operating or something you plan to connect and begin using again?
