Question on PE LC-95 UV detector
Posted: Fri Aug 04, 2006 5:19 pm
We have an old PE LC-95 UV detector that is working fine at wavelength of 313 nm. Currently, we are going to use it at 248 nm for a HPLC analysis. However when we changed wavelength, it can not be zeroed. It always showed "-1" under 285 nm when push the A/Z button (ok above 285 nm). We have tried washing of flow cell with string acid but still did not work. Anybody has clue? Thanks.
