Strange pressure problem
Posted: Thu Aug 03, 2006 8:56 pm
Hi experts!
I have a strange pressure problem:
I have a gradient on a RP C18 column with eluent A: 50-50 (MeOH-H2O) + 5mM Ammoniumformate; and eluent B: 95-5 (MeOH-H2O) + 5mM Ammoniumformate. Analytes are pesticides.
First comes eluent A than B and than A again. During the equilibration with A the pressure increases suddenly! Of course, the 50-50 mixture has a higher viscosity, but the increase is so enormous!!! More than 2000 Psi so that the fittings begin to leak. The column is new!
I had this problem (using this method over months) never before.
Who has an idea?
Thanks!
Who has an idea?
Thanks!
