Continuous pressure increase
Posted: Thu Aug 03, 2006 2:37 pm
Guys,
I have a HP 1050 Quaternary valve Pump.
recently I have started haveing this problem ...
The pump pressure starts rising and the pump eventually stops.
Initially I thought that this might be due to the column...
But then the pressure keeps on increasing without the column as well.
However one more peculiar thing is that at low flow rates like 0.25 or 0.5 ml per min, the pressure remains steady altough a bit high like aroung 40 bar for 0.25 ml/min flow rate but the pressure goes on increasing at flow rates 1ml/min and greater.
the pump then eventually comes to a halt due to high pressure
Any suggestions why is this happening ??
