Monolithic Column Preparation
Posted: Tue May 09, 2017 7:49 am
I'm looking for help in the preparation of silica based monolithic column.
I fabricated monolith in a sealed glass tube with internal diameter of 0.5mm. It will undergo hydrothermal process at 80 degree celsius for 25 hours for gel network formation. However, the monolith was cracked. Does it due to the pressure accumulated inside the glass tube (exert on the monolith and cause cracking?) ? Or any other possibilities?
Thank you!
Thank you!
