GC-MS idling method leads to shutdown
Posted: Mon May 08, 2017 3:57 pm
I found my machine in the shutdown status after running a sequence, and it would be greatly appreciated if I can receive some inputs.
The machine set up:
Agilent 6890 with Gerstel MSP2
Flip top inlet closure with General purpose Merlin microseal
After a sequence, the machine shifts from a regular testing method of 2.2 ml/min (~35 psi) to an "idle/conserve/hibernation" method of 0.5 ml/min (~7.5 psi) (no change in inlet temperature).
Before starting a sequence, I check to make sure that the machine is stable at the "idle/conserve/hibernation" parameter for at least 1 hour while I prepare the samples. However, after a sequence, I found the machine being left at the shutdown status due to pressure not being able to be achieved.
No leak is detected, so I usually remove the septum, re-install it, and that seems to work...
Is it possible that the machine is just not very stable at such low flow rate?
I am out of my wits, and it would be greatly appreciated if I can receive any inputs!
Thanks!
The machine set up:
Thanks!
