Filtering samples before analysis by IC
Posted: Fri May 05, 2017 2:22 pm
Ok, so I am now having a problem with our new QA/QC officer on methods EPA300.0 and EPA300.1. He is saying that since the method says we must inject a well mixed sample, that we MUST shake the sample prior to injection and not filter it before it goes on the instrument. When we argue the point that it needs to be filtered he says that the EPA chemist are more experienced than we are and if it needed to be filtered they would have put that into the method.
Does anyone know of any official reference that I can use to show that the samples should be filtered prior to analysis?
I am afraid to show him that the autosampler has an inline filter for when it loads the samples for fear he will want to have that removed also. He is arguing that it is "good chemistry practice" to mix the sample before injecting it, but is ignoring the "good chromatography practice" of proper sample prep.
Any reference would be much appreciated, especially if it comes from a government agency link.
