Karl Fischer Reagent & Sample Prep
Posted: Wed Aug 02, 2006 2:19 am
Hello:
Please help w/ the following questions regarding KF:
(1) Hydranal Composite 1, 2, and 5 differ in their "strength" of titration (e.g. 1 mg H2O/ml for Composite 1; 2 mg H2O/ml for Composite 2). Since a smaller amount of the "stronger" reagent (e.g. Composite 5) would be required to titrate the same amount of H2O as compared with a "weaker" reagent, why not just use Composite 5 all the time?
(2) For ketones & aldehydes, it's best to use Composite 5K. For all others, can we use Composite 1, 2, and 5? In other words, are there any special cases I need to watch out for?
(3) For testing uncoated and coated pellet samples, is grinding needed? I'm not even sure if these are soluble in CH3OH...
Thanks. I appreciate it.
Liz
Liz
