Since we'll get a new LIMS-System which collects all results from our GC-Computer (PDF and TXT), I have tried to write an automated Export-Method which directly displays the correct sample names as filenames (without additional manual typing).
Anyway, when exporting the report, empower saves it under the 'result ID' as filename.
We now want Empower to save the report under the 'sample name' (we type in the sample name in the 'Sample Set Method' into column 'sample name').
Does anyone now if this is possible or how we can solve this problem?
many thanks in advance!
