wine analyse with gc
Posted: Tue May 02, 2017 11:16 am
hello.i want analyse methanol in wine with gc.which standart i must use?from which company you booked it?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
https://www.chromforum.org/
I believe that is the density of ethanol."The concentration of ethanol in alcohol drinks is always absolutely accurate and it is 789270 mg per liter of absolute alcohol (ethanol)."
Is this the concentration of ethanol in what you usually drink ? If so it would explain some otherwise puzzling phenomena.
It is indeed the density of ethanol (at a particular temperature), and confusing density with concentration is not a good start for accurate results, even if using the ethanol that is already in the drink as an IS did not violate several well established analytical principles.I believe that is the density of ethanol."The concentration of ethanol in alcohol drinks is always absolutely accurate and it is 789270 mg per liter of absolute alcohol (ethanol)."
That method would report the methanol content as if the beverage was 100% ethanol. Then it could be corrected for the ethanol content of the actual wine. So if you have 10ppm Methanol by the test and the wine was 10% ethanol then there would be 1ppm Methanol in the bottle of wine.
Sounds like typical government agency, make reporting units something totally obscure that no one recognizes just to give another hoop to jump through )
In fact this unit has got sense. Permissible methanol content in alcoholic drinks is connected with ethanol concentration. The more concentrated ethanol, the more methanol content is permissible - that's why this calculation for absolute ethanol is used. Nb. for accidents with methanol intake, the remedy is ethanol....Sounds like typical government agency, make reporting units something totally obscure that no one recognizes just to give another hoop to jump through )
@ dblux_ Not so simple.In fact this unit has got sense. Permissible methanol content in alcoholic drinks is connected with ethanol concentration. The more concentrated ethanol, the more methanol content is permissible - that's why this calculation for absolute ethanol is used. Nb. for accidents with methanol intake, the remedy is ethanol....Sounds like typical government agency, make reporting units something totally obscure that no one recognizes just to give another hoop to jump through )
Yes, but seems to me that original poster was a one time visitor here from May 2nd. Lets assume that he or she is no more interested in this analysis...The original post was asking how to measure methanol in wine and wine is not equal to absolute alcohol since it normally is a mixture with approximately 15% ethanol and 85% water.(with many other constituents of course)
Taxes have nothing in common with permissible methanol content in alcoholic drinks....@ dblux_ Not so simple.
Ethanol containing products are an excisable products. So, accounting for such goods is carried out in terms of absolute ethanol.
Siarhei
Siarhei, the above mentioned regulation doesn't explain why methanol content is expressed in mg/L (AA). It only arbitrarily introduces such unit what we took for granted.@ dblux_ The fact that spirit drinks are excisable goods has led to the fact that the values of concentrations of volatile components need to be determined in mg per liter of absolute ethanol [mg/l (AA)] (see REGULATION (EC) No 110/2008 and COMMISSION REGULATION (EC) No 2870/2000). A detailed description of this circumstance is presented here https://www.youtube.com/channel/UCXgL2c ... lW1oxOGqtQ .
...Siarhei
If you are working from an unknown product you will have to run an analysis to determine ethanol concentration then run the methanol test afterwards. Here we would just have ethanol and methanol in a standard and run them both at the same time in one injection.@ dblux_ The fact that spirit drinks are excisable goods has led to the fact that the values of concentrations of volatile components need to be determined in mg per liter of absolute ethanol [mg/l (AA)] (see REGULATION (EC) No 110/2008 and COMMISSION REGULATION (EC) No 2870/2000). A detailed description of this circumstance is presented here https://www.youtube.com/channel/UCXgL2c ... lW1oxOGqtQ .
@ James_Ball The concentration in mg/l can be easy obtained by the following simple formula:
Concentration of methanol[mg/l] = concentration of methanol[mg/l (AA)] * “strength [%]”/100[%].
As a consequence, in the case given by You with approximately 15% ethanol, the calculated value of the methanol concentration in the dimension of the [mg/l] will be 15/100 times the concentration in the dimension of ”[mg/l (AA)].
Siarhei
Dear Dblux_ ,Siarhei, the above mentioned regulation doesn't explain why methanol content is expressed in mg/L (AA). It only arbitrarily introduces such unit what we took for granted.@ dblux_ The fact that spirit drinks are excisable goods has led to the fact that the values of concentrations of volatile components need to be determined in mg per liter of absolute ethanol [mg/l (AA)] (see REGULATION (EC) No 110/2008 and COMMISSION REGULATION (EC) No 2870/2000). A detailed description of this circumstance is presented here https://www.youtube.com/channel/UCXgL2c ... lW1oxOGqtQ .
...Siarhei
Would you be so kind and post here an excerpt from regulation you linked clearly stating the reason of expressing methanol in relation to absolute ethanol ?
TIA
