USB-GPIB issues with 5890 Series II
Posted: Mon Apr 24, 2017 2:33 am
Folks,
Mechanical Engineer here dropping into your realm. Help is appreciated. Recently purchased the following
5890 Series II
7673 Injector W/Tray
G1512A controller.
82350B (inside a computer that sauced itself)
82357B Interface (used, seems to be legit)
Machine was supposed to be operating fine. Prior owner hooked it up the night before in low temp conditions and a capacitor blew on the host computer. Computer was inoperable.
We renegotiated a massive price drop. All machines power on, GC passes self test and sets all temps. Figuring it out.
Meanwhile - the issue.
I am attempting to run this machine on a virtual box installation. I pulled the old hard drive from the machine, built a virtual drive off of it and it booted right up. Pulled my serial numbers for chem station.
Installed IOLibSuite 16.3
Mounted the 82357B to the virtual machine
Ran the configuration.
Following information from this thread
viewtopic.php?t=24063
I have set the USB SICL interface ID to hp82341. GPIB address is 21. VISA interface IS GPIB0. Logical Unit 7. Auto Discover on.
This thread confirms the renaming.
viewtopic.php?t=13641
USB adapter is configured and the HP7673A shows a good connection. Talking correctly.
The 5890 is communicating with the USB interface, but returns a communication failure "The instrument failed to return an IDN string"
Where do I go next with trouble shooting this? Apparently... google doesn't document tribal knowledge from the 90's very well.
5890 Series II
G1512A controller.
