shark fins and overload solvent peaks - OK???
Posted: Fri Jul 21, 2006 10:43 pm
Say youre running tests and youre using a small amount of a component in a solvent. Say youre testing for the presence and if so, concentration of the component in the solvent via FID.
Youre going to get a 'solvent peak', and its going to be real high, wide, look like a shark fin, and obviously be overloading the column... but to split it will prevent you from seeing really low concentrations of the other component.
Does it really matter that the solvent peak is so abnormally shaped, so long as you get a nice gaussian when the other component eludes in quantity??? I guess, in other words, no matter how ugly your solvent peak is, so long as the baseline goes back to zero prior to the other thing eluding, can you just automatically ignore the solvent peak, no matter what?
Thanks for the help and clarification!
JMH
JMH
