Two in progress status when running GC Agilent
Posted: Mon Apr 17, 2017 3:35 am
by daonguyen
Hi all,
Please help me out, I am running GC Agilent using Chemstation sofware with 1 sequence. The sofware recently apprear two status of in progress, please see the attached picture.
https://goo.gl/photos/6TEaWhCTcAdDrL6u8
Thank you guys so much for your help.
Re: Two in progress status when running GC Agilent
Posted: Fri Apr 21, 2017 1:34 am
by Himar
Go to that datafile location in Windows explorer. You will find it has an extra file that your other datafiles don't have (acquiring.txt i believe?) Once you remove that, in progress should go away.
Posted: Fri Apr 21, 2017 3:25 am
by daonguyen
I did as your support and it was actually fixed。 But I still wonder why this extra file appeared, because I did the same actions with other location files (creating sequence, choose data location,run sequence)。Others appear normal, but this one is quite different.
Thank you so much for your support me!
