split peak with mobile phase
Posted: Fri Jul 14, 2006 9:03 pm
For the analysis of Paclitaxel we follow the USP method. Paclitaxel is diluted in methanol (acidified with acetic acid). Mobile phase is acetonitrile/water, and the column is a taxane specific PHP column.
Under some circumstances I need to use THF as a diluent for this product. THF is about the only solvent that disolves the drug and an excipient that forms the product matrix. I do not know of any way to separate the drug from the excipient once they are both dissolved together.
When I inject a sample of paclitaxel dissolved in THF, the chromatography has a split peak. Is there any explanation for this, or ways to avoid it? The split peak is not caused by excipients. I can make a standard solution of paclitaxel only dissolved in THF and get the same split peak. I will also try this on a C18 column, but have not done so yet.
thanks
thanks
