HP1100 autosampler problem!
Posted: Thu Jul 13, 2006 9:29 pm
I have a problem with an HP1100 regular autosampler (G1313A). In the past I had a couple of errors pop-up that said motor 2 overheat (theta gripper motor I assume). This occured mostly in runtimes under 5 minutes and my runs would stop... I didn't have a problem with it since I now used 10min runs between injections however about a year later and now I got this problem once last week and this week the injector will not reinitialize when the power is turned back on. It stops in the middle of initialization and says in chemstation: initialization failed (3028) or (3022).
Now it makes a sound like something is forcing but I cannot figure out where it comes from. An electrical technician did take resistance of motor 2 and 3 and both gave 40ohm so coils seem to be ok... each motor also gives small pulses at the beginning of the initialization and if I move the unit by hand it will sometimes move always to the farther top left corner and stay there... everything seems to be clean in there so I was wondering if it could be the encoder in motor 2 that is the problem or could it be the transport assembly or mainboard that short circuited??
Can also someone tell me in the early steps of initialization of the ALS if the 3 grippers that grip vials move in the first seconds? because I do not see that happening, thats from motor 3....
Hopefully I can get some help from this forum.
Thanks!
fbreton
Thanks!
fbreton
