Troubleshooting Callibrationcurve far away from Zeropoint
Posted: Wed Apr 12, 2017 12:22 pm
Hello Everybody
I work in a Distillery analysing our products and incoming raw Materials with an GC using FID detection.
Recently i recallibrated the System and afterwards an anomaly appeared which i cannot make sense of.
I have checked and double checked my Steps, calculations and Settings but found nothing wrong.
So i turn to You in hope of getting an idea whats going wrong here.
Usually i force the calibration Curve thru the Zeropoint. It makes Sense to me that Zero Concentration should equal Zero Detector Signal above Baseline. This has until now worked nicely for me as the callibration Curve did match up with the zeropoint with minimal deviation.
In my latest Callibration one of 34 Substances in my Standard came out different. The 36 Datapoints (6x6) show a linear Line but the Slope in no way fits the Zeropoint.
I made some Pictures so you can see my Problem:
With this i have two Options and none of them is really satisfying:
1. Ignore the Zeropoint and work with The Linear callibration Curve providet by the Data. This results in negativ Values for lower Concentrations. I can hardly send out Analysis-Reports containing negative Concentrations as this is plain false.
2. Force Zero and have R-Squarred at 0,79 when it should be at least 0,99. This callibration Curve does not really have any relation to real Concentrations and is thereby unusable.
Basically this Callibration is not usable and i dont know what caused it.
I have done two Callibrations recently and both came up with this problem so it aint a one time Thing either.
In my earlier Callibrations this Problem did not occur, therefor the error whereever it lies must have come with this new Callibration and it only happens for one out of 34 Substances.
Furthermore i have run Blankruns before and after the Calibrations which show nothing but a Baseline.
Im at my wits end and i hope one of You see´s where the Problem lies or has encountered this himself in the past and can help me get it fixed.
P.S.: i read the Sticky "Embedding Chromatograms and Reports" but when i resize my pics to 400x400 you cant read or see anything as it all get a pixelmess. Hope you can life with the big pics.
Thanks for your efforts,
SpiritAnalytics
SpiritAnalytics
