the union between transfer line of G1888 and GC6890
Posted: Tue Apr 11, 2017 11:54 pm
by Lijun-Zhang
I want to connect the transfer line of G1888 to the carrier gas tubing of injection port of G6890. But the union I have isn't correct. I guess the nut of carrier gas tubing from injection port is 1/16 inch. But the end of transfer line is a metric male nut. Could anybody tell me where I can buy the zero dead volume union with two different female connectors? And the part number too. Thanks
Re: the union between transfer line of G1888 and GC6890
Posted: Wed Apr 12, 2017 12:07 am
by Lijun-Zhang
The machine is Agilent G1888 and GC6890
Posted: Wed Apr 12, 2017 6:23 am
by tkubowicz
Hello
It is easier to cut tip of HS transfer line and install 1/16 nut.
Just remember to connect transfer line very close to GC inlet to avoid "cold spot".
Regards
Tomasz Kubowicz
Posted: Wed Apr 12, 2017 12:48 pm
by GasMan
Agilent has a part number to enable the M5 nut on the HSS transfer line to connect to 1/16 tubing. Part number is G3521-80000
Gasman
