respected forum...,
myself a master of pharmacy student from india would like to clear a query about separating my degradation product for HPLC,NMR and LC-MS.
Readers, i do perform my dissertation work in development of a stability indicating method using chromatographic methods for anticancer drugs.
as, my stability studies have come to an end and i would like to isolate my degradant by completly degrading my drug.for tht i used hydrogen peroxide and applied high conditions for degradation,but the problem arises tht after degradation am unable to separate my degradant from hydrogen peroxide,i did employ heating to dryness and vaccum dring too in both cases the result was tht the hydrogen peroxide just made foam and left but nothing remained in the round bottom flask.
as my drug is acetonitrile and methanol soluble i tried using the solution for extraction then as the result was similar to as i mentioned above,i changed my procedure as taking the drug 50 millgram and directly adding hydrogen peroxide and doing degradation. the results obtained are as mentioned above.
respected readers i would like know or would request u r help to solve this problem...
thanking you,
vivin
