Allopurinol related substance assay - inconsistent peaks.
Posted: Wed Jul 05, 2006 3:57 pm
We have had a persistent problem with this assay following the BP procedure which is a gradient method up to 30% MeOH.
The Allopurinol peak, which greatly overloads the column varies from injection to injection. The peak can then swamp the small related substance peaks.
I thought I had solved the problem by introducing a wash step going up to 70% MeOH. This did improve things but still there is an occasional broad allopurinol peak.
