Shifting RT of Pyrazinamide and IS Peaks
Posted: Thu Jun 29, 2006 7:44 am
Hello all:
We are validating a method for the determination of pyrazinamide in human plasma by HPLC UV. We are encountering retention time shift. We already did the following:
- pump check: flow rate is ok
- leak checked: none
- column temperature maintained at 27 degrees
- mobile phase equilibration from 1 to 2 hours at 1 mL / min
M.P.: 20 mM of Phosphate buffer/ Methanol, 96.8:3.2, pH 7.4
Sample Prep: 200 uL of plasma precipitated with 50uL of 20% Perchloric acid, 150 uL of supernatant is neutralized with 1M NaOH. 20 uL injection into the HPLC system.
Column: Phenomenex Luna C8, 4.6 x 250 mm, 5um
Retention times of Pyrazinamide and IS (Sulfanilamide) decrease all throughout the analytical run (e.g. from 9 minutes to 6 minutes). Where could be the problem?
Any feedback is appreciated. Thanks.
-ghie-
-ghie-
