GC Headspace using Empower 3
Posted: Sun Mar 26, 2017 4:33 am
Hi all,
I would like to ask regarding the GC headspace that uses Empower 3.
As i have run a set of 19 injection sample on Empower 3. However, for the last injection, it stopped run at 28 min, in which the usual run is 45 min.
Furthermore, when i went to check the message center, there is an missing vial 20 and vial 21. However, according to my sample set, i only have 19 vial. Furthermore, the default sample set only has 19 vial.
In addition, during the trial, i already has run 8 vial, and there is no issue. Only when i run 19 vial, this issue then come out.
Can i know how to i troubleshoot for this, i would hope that the run will not stop at 28 min.
Thank you in advance.
