I have issue in running of samples such as GPC and Varian GC in which use the e-Sat/IN to connect to Empower 3, i cannot synchronize the run.
For instant, the GPC uses ClassVP to run the sample. When i tried to run the sample in Empower first, the Empower will capture the result immediately even the GPC has not start run in ClassVp. Therefore, I will have a have delay of peaks generated in Empower. E.g. the first peak present in ClassVP is 42 min, while the first peak present in Empower is 45 min.
While for Varian GC, which also faces the same issue. As i also tried to run the sample in Empower first, the Empower will capture the result immediately even the Varian GC has not start run in chromeoleon. Therefore, I will have a have delay of peaks generated in Empower. E.g. the first peak present in Chromeleon is 4.5 min, while the first peak present in Empower is 8 min.
While i also have IC in which also uses e-Sat/IN to run. This IC which runs in Empower, can have an instruction like "Waiting for an injection". Therefore, this IC does not have issue in collecting the result.
Can I know how do i make the GPC and Varian GC to be able like IC that can have synchronize the run like present of "Waiting for injection" in Empower. Thank you in advance.
