Column installation into UNIS PTV inlet
Posted: Fri Mar 17, 2017 6:38 pm
by James_Ball
Does anyone know the proper column installation depth into a JAS UNIS 2000 PTV inlet?
We have one I am trying to use again, but the manual is no where to be found and I can't find it online either. I know the Gerstel CIS4 uses ~17mm from bottom of the ferrule, but I'm not sure on the UNIS 2000.
Re: Column installation into UNIS PTV inlet
Posted: Thu Mar 30, 2017 6:05 pm
by Rolkizz
I have the manual of UNIS. There is a detail information of installation. If you still need it, I could send it by email.
As JAS UNIS inlet often is used for GC/MS coupled with TGA, maybe do you have such system?
