New to Gas Chromatography with questions
Posted: Mon Mar 13, 2017 5:12 pm
I may be asking a bit more than I should here but, I am very new to Gas Chromatography and would greatly appreciate any help I can get.
Background:
I "inherited" a job with a company that does Natural Gas Measurement, which consists of installing, calibrating, and maintaining meters for companies that produce oil and natural gas. We also collect and analyze gas samples to determine the content of the gas so our customers can have data to ensure that their reported volumes are correct when dealing with purchasers.
I have 2 Varian CP-3800 gas chromatographs that I run samples on daily. The boss who taught me how to run them had over 20+ years experience in the field and these were his 2nd and 3rd machines. He retired a bit earlier than I expected him to and only taught me the basics about the chromatographs.
I understand how to make sure the machines are physically ready to run samples, how to inject samples, what they do while running a sample, and how to read an analysis. I am only asking questions because I cannot find an type of manual or other instructions online that contain answers that I can use.
My questions are actually very basic and might sound foolish, but:
According to my (now former) boss, if we put the chromatographs on a "Standby" method for more than an hour or so they need over 8 hours to fully stabilize after activating an "Analyzing" method. Question: Is there actually a minimum amount of time that I need to wait after re-activating a chromatograph before I run samples? When I put them on Standby for a few minutes to change gas tanks I usually wait at least 30 minutes after re-activating a method before I run samples (per Boss' instructions, so the columns can re-heat or the helium flow can clear). Do I need to wait any longer any other time?
Also, my boss also stated that unless there was a power outage the chromatographs should always stay on partly because of the question stated above and he said that turning the machines themselves off and on too often could cause issues when re-starting them. I've read a couple of posts on this forum regarding chromatographs getting stuck when initializing but, is there any other reason they can't be shut down for a weekend and re-started without issue on a Monday?
I realize I've typed a lot here but I'd really appreciate any help I can get. My main concern is time, as in I need to manage it so I have as little down-time as possible. I am asking these questions here because I've had no luck finding answers in any of the manuals or discussions I've read concerning these machines. If anyone has answers or a link to any material I can access that will help me, I'd appreciate it greatly. If you've read all this, thank you!
Background:
