Low Pressure Ion Chromatography Column
Posted: Mon Jun 12, 2006 3:58 pm
by sball
Dear all,
I have been informed that there is an ion chromatography column that operates at a much lower back pressure than normal columns of this type. Apparantly, the typical back pressure of a standard IC column is 50-70 bar (although this would obviously depend a bit on the mobile phase used), so I am assuming that this new column operates at pressures below that.
I'm told that this column was introduced at Pittconn in 2002, so I was wondering whether anyone has ever come across it and, if so, from whom can it be purchased?
Thanks for your help.
Steve.
Posted: Mon Jun 26, 2006 9:56 am
by Markus Laeubli, Metrohm
Dear sball
Operating pressure is not the mostly used parameter to differentiate between IC columns.
Anyway Metrohm has a couple of columns with back pressure around 60 bar.
For anions with chemical suppression: Metrosep A Supp 4, Metrosep A Supp 5.
For anions non-suppressed: Metrosep Dual 2, Metrosep Dual 3
For cations: Metrosep C2
