New column storage
Posted: Mon Mar 13, 2017 8:20 am
by arnabroy81
I have got a brand new column from Thermo (Syncronis C18). It turns out that I don't need to use it right away. So, I have still not opened the column. Is it okay if I just keep it at room temperature? Or I need to do something for it's storage?
Re: New column storage
Posted: Mon Mar 13, 2017 8:24 am
by tkubowicz
Hello
As you haven't opened column yet it still has storage solvent inside (you will find information about storage/shipping solvent in column certificate).
You can keep box with column (or column itself) at room temperature.
Regards
Tomasz Kubowicz
Posted: Mon Mar 13, 2017 2:43 pm
by Consumer Products Guy
It will be fine. Or since seal is unbroken, maybe you can return it.
Posted: Tue Mar 14, 2017 7:27 am
by Gerhard Kratz
I agree with Tomasz. It is always good to have a brand new column in the back hand, just in case.
Posted: Tue Mar 14, 2017 3:12 pm
Agree; always good for determining if the column is the issue when a problem shows up. I always had at least one back-up new column for each of our pharmaceutical assays, both HPLC and GC.
Posted: Tue Mar 14, 2017 5:15 pm
by DR
Probably more true in the lab than anywhere else - when in doubt, read the manual. Even columns come with them.
Posted: Thu Mar 23, 2017 11:26 am
by arnabroy81
Thank you guys.
