From .MS to .RAW Openchrom - xcalibur
Posted: Sun Mar 12, 2017 11:06 am
Hi all,
In order to work a file.MS (Agilent) with the software xcalibur (.RAW), I was able to :
1) convert a file (chromatogram + mass spectrum) from .MS (file.MS) to .CDF (file.CDF) by using Openchrom (no error when converting)
2) then convert the previous file.CDF to file.RAW by using xcalibur (no error when converting).
Unfortunately, when I open my file.RAW with xcalibur, I obtain an empty chromatogram that I can not exploit...
Do you have a solution for me to convert these files correctly ? I use Openchrom and xcalibur but I have not Chemstation. Thanks.
