Shimadzu FCV-12 install in CTO-20A oven?
Posted: Wed Mar 08, 2017 11:09 pm
Does anybody know how to install an FCV-12AH 6-port valve in a CTO-20A oven? (Both parts are from Shimadzu.) I figured out where I can update the instrument configuration in the software once I get the valve installed... but I'm unsure of the connection between the oven circuit board jumper location (eight pins) to the subcontroller on the back of the valve (SCSI-ish looking).
Any help is appreciated!
