Peak shape and pressure
Posted: Thu Jun 08, 2006 12:30 am
I've never heard of any HPLC training instructor talk about the effects of system pressure on peak shape. So I'm in uncharted terrority here.
On my IC I've noticed that the more pressure I apply to the system, either by ramping up the flow rate or adding restictor columns, my peaks are getting higher. Because I also have a background in GC I'm not surprised. My problem is I think I'm getting too fast for the system and my pressure is not as high as I'd like it to be (it's only around 1000psi).
Does adding pressure actually improve peak shape or am I just wistful thinking?
What can I do to add more pressure? Should I start changing out my connection tubing to smaller IDs?
Thanks in advance
Thanks in advance
