Shimadzu 10Avp-LC and API 3000 Sciex MS communication
Posted: Sun Mar 05, 2017 9:17 pm
by dickmuoki@gmail.com
Can API 3000 Sciex Mass Spec running Analyst version 1.5.2 work with a
Shimadzu system having the following modules?
System Controller = SCL-10Avp
Auto Injector = SIL-10A
LC=LC-10Avp
Column Oven = CTO-10A or CTS-10ASvp.
UV Vis Detector = SPD-10Avp
My biggest concern is that the HPLC system above SIL-10A
while the Analyst 1.5.2 manual in the link below only lists SIL-10Avp
http://download.sciex.com/Analyst_1.5.2 ... -guide.pdf
Does anyone here have experience with API 3000 – Shimadzu system with the
modules as listed above?
When using the LC as front end for MS, do you have to use the controller or
the UV Vis (maybe the network card is installed in one of them)?
Thanks in advance.
