Varian 4000 MS - problem with filament
Posted: Thu Feb 23, 2017 9:23 am
Hello everybody,
I have a 12-year old Varian 4000 MS, I've been working on it for 10 years.
As far, the filament has been burning out usually after a year. Last year we had to change the filament after 10 months, but we thought that it was due to a lot of analysis that we had been doing. However, a new filament, which has been installed on 9 February, worked for only two weeks! Yesterday I was given a communicate that filament 1 was open....
Hence my question to more experienced colleagues: what could be the cause of the crash? I use solvent delay, the samples are not concentrated, I usually switch the filament for only a short time. Any of other working parameters didn't changed. Emission current = 10 uA. Vacuum is ok. I analyse mainly food samples, in particular acrylamide and MCPD, after derivatization.
Is it possible that it is a problem with e.g. failed current sensor and filament gives too large current? Or something is not connected properly and that's why the system displays the communicate that the filament is open? Or the new filament has got some hidden defect?
