Blank correction in EMPOWER-3
Posted: Sat Feb 18, 2017 7:27 pm
I am trying to subtract area of blank from standard and sample for a particular peak present in blank, standard and sample.
The Syntex of CF I am using is: Area-(Label ..(Area))
When result search criteria is "result set only" it's not working. But when result search criteria is "result set first" it's working, when the sample set is processed for 1st time.
When processing second time by changing the processing parameter, software is subtracting area from 1st result.
Please help to solve... Any possible way for execution of blank correction (using label and custom field) is welcome but not through method set.
