Signal Names Changed
Posted: Wed Feb 15, 2017 2:00 pm
I have an Agilent 7890A with two columns, detectors and inlets. We run Chemstation B.04.03. For as long as I can remember, the front detector signal was FID3 B and the rear detector signal name was FID1 B. There was a headspace unit connected to the rear inlet. Last week, we disconnected the headspace unit to do some work with direct injection on the rear column and this week reconnected the headspace unit.
Now all of the sudden, FID1 A is the from detector signal and FID3 A is the rear detector signal. So, all of our methods try to collect signal from the wrong column and all of our calibration tables are invalid. Any idea how to change this back to the way it was? or modify the calibration tables to use the new signal name?
