Cetyl palmitate
Posted: Thu May 25, 2006 1:11 pm
by Torres
I need to make the analisys of cetyl palmitate using de Ph. Eur. monograph and i use a capillary column that doesn´t resist the high temperature, anybody nows a reference of a column to make this analisys, the column is a
Stainless steel column : l = 10 m, diam. = 0.53 mm, film thickness = 2.65 µm, HP1
Posted: Thu May 25, 2006 6:03 pm
by Consumer Products Guy
I've used high-temperature Ultra-Alloy SS columns from http://www.quadrexcorp.com/ see if they can supply that dimension.
