What to do with a (PE) PHOTOVAC Voyager PID Portable GC?
Posted: Sun Feb 12, 2017 9:35 pm
by KalleMP
Hi Good folks,
My first post here, I have learnt a lot from reading but hope to gain more ideas from those more skilled in the art. I am a potential hobby user of GC and there is little activity in Finland that I have found. Below a long writeup to save you the good reader from having to ask too many questions.
I have recently acquired a used, not working, PerkinElmer PHOTOVAC Voyager PID Portable Gas Chromatorgraph first launched between 1997 and 2001 I believe. The division was sold off and is now at Inficon and this unit was renamed the Explorer before it was discontinued in August 2015.
The unit came with nothing else but there is a user manual for the final Inficon Explorer version and the nearly identical earlier PerkinElmer Voyager model on-line as well.
It is a pretty neat explosive atmosphere rated unit that looks pretty low mileage. It has a sample loop and syringe port and 3 parallel columns and a UV Photo Ionisation detector. It has place for an optional ECD detector that is not fitted. It has an internal 8 hour gas cylinder for Nitrogen or Air Zero. It has a 9 hour smart battery pack with internal (faulty) charger circuit that has 6 x 5500mAh Ni-Cd D-cells with 0.0V across the cells.
It does not have any protection over the sample port which is a pity and the gas as expected reads 0 PSI. I have no injectors, no gas or filling rig, no spare septums, no communications cables, no software (PerkinElmer supplied something elusive called SiteChart), no reference standards. If the burnt PCB track (and perhaps a couple of nearby components and the cells) is all that ails the battery pack I think I can repair it. I have pinouts for the MiniDIN 8 serial connector from an older PHOTOVAC (pre PerkinElmer) model that I will assume is compatible unless I read otherwise and can make a cable if required to log printer output or dump data files or upload firmware, assays or compound libraries if I can get suitable files and software. I will find a suitable mains adapter (10 to 18V DC under 2A by my calculations) if the bench PSU tests out ok.
It is intended to measure volatile organic chemicals in air, gases and head-spaces. It is a simple to operate unit and I saw mention somewhere that operating costs with consumables was around US$25 per day. That would be gas and septums mostly with the periodic UV lamp cleaning and occasional replacement. I do want to play with a GC one day.
I have a number of questions that will help me determine the future of the unit.
Firstly it has a DA15 female connector near the sampling port, is this perhaps for an auto-sampler of some sort, I did not see it mentioned in the manual?
I already looked in the battery pack and found an obvious fault. I am itching to look inside the main EX sealed unit, if I take great care and do not open any gas fittings is it safe for me to explore inside?
I am interested mostly for fun in testing the make up of commercial volatile solvents, denatured alcohols and consumer spirits. I am not sure if the columns and detector are ideal but could it be used for such applications?
If I wanted to transport samples collected in the field what sort of vials would make sense for manual head-space sample injection?
If I were to sell it what might be the value of such a unit if it were to wake up?
Could I hope to trade it for something more classic like an old HP setup that would be working and cheaper to run (software, consumables, columns, detectors)?
Should I delay my exploration and battery pack repair until I have found out if it has a tempting resale/exchange value that I don't compromise by poking around inside?
Would anyone be interested in seeing pictures of the insides?
Many thanks for your time taken to read this long essay.
Re: What to do with a (PE) PHOTOVAC Voyager PID Portable GC?
Posted: Mon Feb 13, 2017 7:12 am
by KalleMP
Hi all,
Here is a list of some of the standard assay options. I see methyl and ethyl alcohol and industrial solvents are listed so I suppose it should work for me. Being able to determine the solvents in glues and paints is also of interest to me.
I see listed indoor air quality, this could even be a revenue generating sideline if the listed chemicals are common. While this is a big topic in Finland these days the primary suspect is usually fungal toxins that they sniff out with trained dogs.
It does look like a very capable universal instrument.
Environmental (Assay #1)
Forty VOCs, including those listed in U.S. EPA Methods 8240 and TO-14
Petrochemical/Refining (Assay #2)
Methanol, ethanol, methyl t-butyl ether (MTBE), t-amyl methyl ether (TAME), benzene, toluene, ethyl benzene, m-xylene, o-xylene
? (Assay #3)
ABS Rubber (Assay #4)
Acrylonitrile, styrene, 1,3-butadiene
Pulp and Paper (Assay #5)
Hydrogen sulfide, methyl mercaptan, ethyl mercaptan, methyl ethyl ketone (MEK), dimethyl sulfide (DMS), dimethyl disulfide (DMDS), alpha-pinene, methanol, acetone, surfactants and sterilants
(Assay #6)
Ethylene oxide, propylene oxide
Latex Polymers (Assay #7)
Methyl acrylate, ethyl acrylate, isobutyl acrylate, nbutyl acrylate, methyl methacrylate, acrylic acid, vinyl acetate, ethylene, styrene.
Chemicals
Various volatile organic compounds (VOCs), chlorinated solvents
Pharmaceutical
Methylene chloride, acetonitrile, chloroform, acetone, toluene, hexane, methyl ethyl ketone, isopropanol, xylene, methanol
Agricultural Fumigants
Phosphine, bromomethane, sulfuryl fluoride
Indoor Air Quality
Acetone, benzene, chloromethane, ethanol, n-hexane, m-xylene, p-xylene, 2-propanol, toluene,1,1,1-trichloroethane
Adhesives
Toluene, acrylate esters, industrial solvents
Posted: Fri Sep 29, 2017 5:51 pm
by abinc
How is your information search coming along? I am considering an older model of Photovac. The GC I used for years was a dandy machine made by SRI, but it is not a field machine. If I buy the Photovac, I would be interested in adapting it to differing carrier gases, as needed. I would also consider if it can be connected to a laptop for better data analysis. I have years of experience with FID so would be interested in that sort of adaptation, as well. Nothing I've read indicates what type of column(s) can be used. Did the machine that you bought have a column already installed? If so, have you tested it? I would be interested in sharing information with you, if I do buy the machine I have in mind.
Posted: Thu Nov 16, 2017 11:01 am
by JohnBraswell2
Do you find answer for your question? I am interesting in it too!
Posted: Wed Jul 29, 2020 9:02 am
by KalleMP
I have not gone further, I found this thread now as I am packing for a move and was closing up the machine for easier transport and thought I would see if the state of the art had changed in the mean time.
It has 3 switched columns but they are not replaceable so I expect one would be always nervous about contaminating them. It has an optional ECD slot but as standard only used the RF excited PID detector which should be durable.
I saw a parts unit for sale (at inflated price) on the auction site that had pictures of the insides that show the oven (which I did not expose on mine) and it looks identical. The rechargeable battery pack plugs into the multi-pole connector on the back.
I received no accessories with mine so have not played around with it. The electronics are remarkably simple in my opinion with a single processor and everything that can runs on battery voltage directly and it might wake up with just a single 7.2V rail and ignore the smart battery but have not tried it yet.
It has a socketed (FLASH) ROM chip that might be interesting to read, the processor is a 68000 variant I think.
I was thinking to offer it in exchange for a older full-size unit that I can muck about with with someone that wants to try and wake up the portable. It might work very well with some modern LiPo cells.
https://www.ebay.ca/itm/Inficon-Photova ... 3629616447
Posted: Wed Jul 29, 2020 9:06 am
by KalleMP
Nothing new to report. I spoke to a previous user who said the powersupplies gave trouble and on mine the charge circuit in the smart battery pack was burnt out most likely from trying to charge damaged cells for long period.
Serial cable I could likely recreate as it is a mini-DIN and the MAX232 level shifter is right there so pinouts can be deduced if required. Would need to get unobtainable PC software to use the serial port so I have not bothered. There is also a DA15 socket I think labelled SPI on the PCB that may have been for accessories like sample changer but not sure, have not seen mention in documentation. Some good pictures in the auction listing linked in my other reply.
I did find documents relating to the unit.
https://usenvironmental.com/download/ma ... Manual.pdf
https://archive.epa.gov/nrmrl/archive-e ... vr_pep.pdf
https://www.equipcoservices.com/pdf/dat ... oyager.pdf
Posted: Thu Jan 04, 2024 1:34 am
by WMGEOTEC
Hey guys,
I know, I´m a little late to this party, but anyways:
Here you can download the SiteChart Software:
https://www.equipcoservices.com/software/SiteChart.zip
Here you can find the manual:
https://www.equipcoservices.com/pdf/man ... oyager.pdf
Also, I did some reverse-engineering on my GC, regarding the DIN-8 connector:
Has anyone an idea, how to connect this device to a PC?
