PCB Analysis in Transformer Oil
Posted: Fri Feb 10, 2017 10:14 pm
Hi Everyone,
I am working on setting up EPA method 600 for the analysis of PCBs in transformer oil and I am having trouble reporting my results. Right now we run a 7 pt calibration curve (quadradic) standard concentrations are 0.1, 0.2, 0.4, 1.0, 2.0, 3.0, and 4.0 ppm. This is the TOTAL PCB concentration in the sample vial, the problem I am running into is while calibrating, if I put these concentrations into my calibration table in Chemstation it reports that each peak I calibrate for has a concentration of X ppm when in fact the sum of all of the PCB peaks in the sample is X ppm. I was hoping someone could provide some insight as to how to report this, or how to split the total concentration among the 10 or so peaks that come through the GC.
Thanks in advance for the help!
