Methylboronic acid dervatization followed by BSTFA
Posted: Mon May 15, 2006 2:42 pm
I'm experimenting with a method that first uses methylboronic acid to derivatize sugars, then followed by BSTFA to add TMS to any free hydroxyl groups. However, the second step doesn't call for Trimethylchlorosilane.
My question is, does the excess, unreacted methylboronic acid act as a catalyst for the silylation?
And if anyone's wondering, I'm using the method described in Gross and Glaser (2004) RCMS vol 18 pp 2753-2764 and it's worked exactly as it should be on standard mixtures.
Cheers
Cheers
