Unexpected chromatographic behavoir
Posted: Thu May 11, 2006 11:19 am
I've recently been developing a separation and have come across some chromatographic behaviour which I have not seen before.
I'm using a C18 column with a mobile phase containing (0.17% TFA + 0.1% TEA in H20) + (0.05% TFA in ACN) and running a gradient from 10% to 30% to achieve the separation.
The unexpected behaviour comes when I vary the gradient time in order to optimise the separation. I have four peaks which all elute closely together. The resolution for the four peaks is around 0.8 to 1.2, however the elution order and the separation factor don't vary when the gradient time is varied?
A plot of log K Vs tG represents this very well and all four peaks give nice straight parallel lines all with slopes of 0.0015 and intercepts 0.6829, 0.6547, 0.6129 and 0.5872. To me this would imply that they were separated before I injected them on the column?
