column bleed
Posted: Sun Jan 29, 2017 1:38 am
Hi, could someone please explain what is meant by 'column bleed' in GC.
Is it the wearing off of stationary phase in the column as the column ages?
Also would it be correct to say that there are normal (normal background signal by the stationary phase) and abnormal (a rise in baseline)?
thank you.
thank you.
