Waters 501 HPLC Pump
Posted: Fri Jan 27, 2017 6:56 am
by chemgc779
Could someone please provide a link to a video on how to operate a
Waters 501 HPLC pump (or a operator manual)?
Thank you.
Re: Waters 501 HPLC Pump
Posted: Fri Jan 27, 2017 7:24 am
by Gerhard Kratz
Best advice is to contact Waters tech support.
Posted: Sat Jan 28, 2017 12:10 pm
by chemgc779
Gerhard Kratz: thank you for your information but I was wondering if there was a manual for this pump online..
I have found manuals for 510 and 515 online but it is becoming difficult to find one for 501 model.
Thank you.
Posted: Sat Jan 28, 2017 12:30 pm
by HPLC chemist
As I recall (memory is starting to fade) the 501 operation was close to the 401 pump. So look for the 401 manual too!
Posted: Sat Jan 28, 2017 3:23 pm
by uzman
Operation of 501 and 510 pumps are nearly the same , they only differ by design.
501 is a serial piston type , 510 is parallel piston.
Flow control by a thumbwheel switch on both , and there is a upper pressure control knob , thats all.
If you use a control box for frequency control , the output terminals are also identical.
