Peak Sholder appears frequently
Posted: Sat May 06, 2006 2:46 pm
Iam working with MP ACN:H2O:TEA (20:80:0.4) pH=3 on RP-C18 column with flow rate 1.00 ml/min. I use this system in quantification of a drug containing amino group in plasma samples
first, the peak is good but with tailing. The next day i found a peak shoulder in all samples even i made enough conditioning for the column and this shoulder hinders me in getting good linear results...
if TEA is the cause of this shoulder?...is it preciptating on the column... I need a help to improve my peak shape and to eliminate the shoulder,...I think that the diluent is not the reason, because the peak appears well once when it is prepared in water or ACN alone...
so I need your advice....
