IP344
Posted: Tue Jan 24, 2017 7:53 am
by Muhammad Akbar Khan
Hi Everyone,
If someone can help to calculate the ration of valley to peak height as per IP344.
Re: IP344
Posted: Tue Jan 24, 2017 5:10 pm
by GOM
Hi Muhammad
Some more information and clarification on the ratio that you require and the analysis would be helpful.
I don't have method IP344 available - nor will most others - I presume that the IP refers to the Institute of Petroleum?
You could just cut and paste the relevant section on the ratio required
Kind regards
Ralph
