Multiple residual solvents analysis
Posted: Tue May 02, 2006 5:14 pm
Hi everybody,
We have to develope and validate a residual solvents method for an API. The solvents we want to analyze are: methanol, ethanol, acetone, ethyl acetate, isopropanol, dichloromethane, 1,4-dioxane, toluene and xylene. I'm going to use a GCMS and a RTX-624 column for the separation. We have an headspace autosampler (with the heated syringe) and our products is soluble in DMSO.
My question are: Is better to use an unique internal standard for the quantification (es. n-propanol) for all the solvents or to use external calibration?
Which is the best way to analize all the solvents with only 1 method?
I've found in literature numerous methods for residual solvents analysis that don't use an internal standard (but they use a different autosampler with the transfer line and not the syringe):is this system more reproducible than the heated syringe system?
Thanks again for the help,
Have a good day,
Davide
Have a good day,
Davide
