Edit sample set method creation after the run
Posted: Wed Jan 04, 2017 12:51 pm
i would like to ask whether is it possible to alter the sample set method of the sample that has completed the run?
As i have created a sample set method without using the sample set method wizard. I discovered that the sample set method is wrong until i have completed the run.
I would like to ask also is it possible to do bracketing standard without the use of sample set method wizard?
Please advise. Thank you in advance.
Agnes toon
Agnes toon
