Ezchrom: Save Sequence as 32 bit
Posted: Sat Dec 31, 2016 1:36 am
I am importing several data files into EZChrom from Chemstation as .asc files. In order to work with them in EZChrom I need to save them as 32 bit files (.dat). The problem is I have to open each file then file/save as 32 bit which take quite a while. Does anyone know a way to automate this or save an entire sequence as 32bit files?
Thank you,
Damien
Thank you,
Damien
