Questions about LC coupled ESI MS
Posted: Thu Apr 20, 2006 8:58 pm
Hi. It's my first time coming here. Wonderful Place!
Got several questions when I take a course. Could someone help me? Thanks a lot!
1/ I found when coupling HPLC to ESI, the eluent flow of a HPLC is often split prior to ESI. I think it's because the differences between the flow rates. But what advantages of doing so?
2/ I found several common LC buffers like phosphate buffer are not compatible with ESI. Could someone tell me other buffers in such case? And what about the ion pairing reagents like TFA? Are they OK to couple with ESI?
Thanks a lot
Thanks a lot
