Report Method for just Resolution and End (p/v)?
Posted: Fri Dec 16, 2016 8:52 pm
I have a system suit report method which shows the Signal to Noise value of the 2 actives in my sensitivity solution, and after a method update I now need to record USP Resolution between another 2 actives spiked into the same solution plus a failsafe of the End peak to valley (p/v) if Resolution fails, can I incorporate this into the method?
I tried to add a "Component Summary Table" which I was going to group together with the original Sensitivity Solution Table but it just shows the USP Resolution for every single known peak in my sample, I only want it for the 2 actives. Does anyone know how I can do this?
