"Server Busy Switch to" error pauses the Que
Posted: Thu Dec 15, 2016 1:07 am
Running a Waters HPLC set up utilizing MassLynx, we have large amount of samples to process so must run the instrument over night, however, we keep getting an error that states:
"Server Busy
This action cannot be completed because the other program is busy. Choose 'Switch To' to activate the busy program and correct the program"
We have attempted several solutions with false hope, however this error continues to pause the que interrupting sample run time, and putting us behind. Hoping someone has had a similar issue and found a solution.
Yes we have tried turning it off and back on again with no luck!
Thank you for any advice!
"Server Busy
