Calculating of LOD(DL) based on the Calibration Curve
Posted: Mon Apr 17, 2006 8:26 am
Q2B gives us a formulation to the calculation of DL : DL = 3.3 σ/S.
Thereof, s(σ)could be estimated based on the calibration curve, that is, as Q2B said " a specific calibration curve should be studied using samples containing an analyte in the range of DL. The residual standard deviation of a regression line or the standard deviation of y-intercepts of regression lines may be used as the standard deviation."
But, I don't know how to calculate.Would somebody kindly give me a example?
