Method issues - optimal flow rate
Posted: Fri Apr 14, 2006 10:37 am
Hi all,
I running at method on our GC and its giving me a few probs; my suspicion is the flow rate but I'd appreciate opinions!!
The parameters are
flow rate: 10 cm/s
split flow: 2 cm/s
carrier gas: Helium
column dims: 30m x 0.53mm x 5 microns
oven temperatures: 40C hold for 8mins, ramp to 200C at rate of 30C/min
run time: ~ 19mins
I'm expecting 5 standard peaks; at that flow rate I'm seeing 3. I changed the flow rate to 33 cm/s and I managed to see 5 peaks. Unfortunately the method is validated at 10 cm/s!
Any views?
Jane
The parameters are
flow rate: 10 cm/s
split flow: 2 cm/s
carrier gas: Helium
run time: ~ 19mins
Any views?
Jane
